CS-620 Touch Screen flickering
  • Dave10
    • Jul 2008
    • 197
    We got a report of the touch screen on a CS-620 flickering. Went out there and it was flickering at the top of the touchscreen where the darkest tabs are. If you turn up the contrasr with the knob so that the image darkens a bit, it stops. Since then, we have seen 2 others do this. Is this a problem, or do they all do it? Can anyone check some and let me know, please? Thank you.
  • Jules Winfield
    • Jul 2009
    • 821
    I checked one of ours and didn't see the issue you described.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • 23009
      It's got to be the fluorescent backlight or the inverter that drives it. There aren't many other possibilities. =^..^=
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        We've had many issues with the wire harness located in the top left cover. They look OK, unplug and reseat connectors. Also loosen up the harness, because they are real tight.
        My mission here on Earth is to help all you Dum-Dums!
        • Dave10
          • Jul 2008
          • 197
          Will Try, Thanks.
