Kyocera 3060 setting tray for fax
  • wellconnected
    • Oct 2010
    • 23
    Having checked the manuals i am unable to find how to set a tray for incoming faxes can anybody help
    Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    You can only select media type & not specific tray. If you're talking output tray, you can specify it.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • wellconnected
      • Oct 2010
      • 23
      Thanks for that Tony
      I can assume that you must set a tray to a paper type ie: coloured paper and then select coloured paper for your faxes is that right ?
      • tmaged
        • Oct 2008
        • 1890
        You are correct. I thought there was a setting that you could tell it to use the bypass. It's 9:30pm here, so I don't have a machine.
        Hope that helps !
        -Tony
        www.dtios.com
        • wellconnected
          • Oct 2010
          • 23
          yeah there is a setting for mp tray
          setting tray to coloured paper and then setting fax to coloured paper tray works fine
          thanks again
            • 23009
            These setting choices also solve another problem. Since the fax (with original settings) will continue to print on whatever paper is available, I've heard customers complain about faxes on legal size, ledger size, ... whatever is available. With the setting you have chosen you will get a Paper Empty indication when the tray with the appropriate media setting is empty. You just need to educate the enduser to notice "Load Colored Paper." and not just add more paper to the other trays.
            I've got several machine set up this way. It works fine. =^..^=
