KM-1128 dark copies overnight and in the morning
  • Jimbo1
    • Mar 2008
    • 845
    We have an 1128 that gives dark, not black but dark, prints overnight on faxes and in the morning with everything for a little while then goes away for the rest of the day.
    Ideas? Anybody else having this? Sounds like weak cleaning lamp but need input.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
  • peterepeat
    • 84
    Are there any blank margins on the prints or does the darkness go all the way off the paper?
    What are the environmental conditions? Maybe it's possible condensation is forming overnite?
    ...or possibly other equipment on the same electrical circuit kicking on overnite (heater, etc).
    Maybe try & move the machine to another room for a day or 2 & see if it makes a difference....
    • Warstg_20
      • Sep 2009
      • 72
      peterepeat is right...
      • jewen25
        • Mar 2009
        • 197
        "peterreapeat" and "warstang_20" is right,just try copies maybe 15pcs if theres a improvement , i suspect PWB bias have a problem just check......
        ERROR HELP ME AND HELP YOU
        • lvsb
          • Aug 2008
          • 70
          Had this problem a few months ago. Replaced drum unit and HVPS but a dev unit fixed it.
          Good Luck
          • jewen25
            • Mar 2009
            • 197
            Good Luck
            what you mean "Ivsb" the drum and the HVPS high voltage? is damaged?
            • lvsb
              • Aug 2008
              • 70
              What I mean is I replaced the drum and HVPS but that did not resolve the issue. What did resolve the issue was replacing the Dev unit.
