New TaskAlfa181 with dead keyboard
  • NeoMatrix
    Senior Tech.
    • 3513
    I have a month old TaskAlfa 181 that has a dead keyboard. It has interrupt key , c/stop key and copy keys. All other keys have no function. The LED's are lit as they all are in normal copy mode. The printer recieves pc print jobs the fax recieves fax's.
    I have fit a new keyboard with exactly the same fault condition. Still same dead keys with new keyboard installed.
    • 23010
    Have you re-loaded the firmware? Current firmware is dated 5-18-2010. =^..^=
    • NeoMatrix
      Senior Tech.
      • 3513
      Yes I tried to do a firmware upgrade but the CF card is 2 GB and the MFD appears to get a read error . Have reformat the brand new CF card an re-copied the firmware , and again the firmware gets halfway through and returns a CF-read-error. Will try again with a smaller 1Gb card or less.
        • 23010
        If you can get it, I'd suggest a 128MB or 256MB CF card. The smaller and slower, the better. =^..^=
        • jewen25
          • Mar 2009
          • 197
          i have experience this problem but in km-1820 model, and i found that the main PWB inductor is damage when i replace its "OK" try to measure the Inductor located in the main PWB i think its the color of inductor is color "sky blue",and try to check also the keyboard l "Resistor" that maybe damage also if you found the resistor is damage? do not try to put the keyboard to the other km-181 that cause of error... try this i hope it well help you...
          ERROR HELP ME AND HELP YOU
          • NeoMatrix
            Senior Tech.
            • 3513
            Thanks Jewen25
            Will keep any eye on the component items you have suggested.....
            Thanks to Blackcat also for the CF card update.
            This forum software did and auto tag match in one of our posts and bought up a CF card URL for Australia . I clicked on the URL link an a purchase was done for 256 CF and 512 CF.
            • NeoMatrix
              Senior Tech.
              • 3513
              Jewen25 Hit the target with the Main Power Board being the keyboard fault.
              I replaced the main power board and we have a working keyboard once again...
              Thanks All
              GDM
              • maya
                • Aug 2010
                • 12
                hai, i also faced the same problem in TA 221, but in my case the problem was in the connector. while fixing the scaner unit, the guy who installed the machine , wrongly removed or not fixed the connector, which is near to scanner board,
                after fixing it properly, its working nice,
                may be u have a diffrent problem, but pls check this also,,,
                thanxs
                A bad workman blames his tools
