KM 3050 Clean Slit Glass Message
  • alpha-omega tech
    • 80
    I have a KM 3050 that says clean slit glass. I turned it off in service mode but still get warnings from the copier on our print management software. We replaced the slit glass and we changed simulation 63 from 0 to a -3 according to what Kyocera Hot Line suggested. The clean slit glass does not appear on the copier but it does appear on the print management software. I know we can flag this not to warn us but we want to take care of this issue. The copies and scans look great through the Document Feeder. Has anyone had this issue before.
  • nathicana
    • Aug 2008
    • 327
    slit glass message
    Try varying sim 068 DP scanning position.
      • 22929
      Other possibilities include:
      dirty white plate
      dirty optics
      defective CCD
      Have you tried any of the settings between 0 and -3?
      • vikingmita
        • Nov 2008
        • 163
        just to eliminate the obvious: duplex glass cleaned too?
