CS-6030 jam 32
  • Dave10
    • Jul 2008
    • 197
    CS-6030 jam 32
    Have a 6030 with a PF-650 deck showing a frequent jam-32. When it does, there will be 2 sheets stuck together in the finisher with the image split between the 2, about 6 inches from the lead. Checked separation and suction fans,cleaned clutches and pullies. Still does it. Works great from drawers. We have NEVER had problems with these before, so I don't know where to start. Any suggestions?
    Thanks.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • madas
      • Aug 2008
      • 313
      Hi Dave10
      You may have checked this but is there any indents on the lead edge of the paper?
      where the paper is put in the draw roughly and sometimes you get the edges scrapped pinching the paper together. just a stab in the dark.
      madas
      • kingpd@businessprints.net
        • 921
        Well, let's start with the simple things first. How often does it actually jam? Do they throw the first and last piece of paper away, sometimes little drops of glue gets on the paper from the wrappers. Do they fan the paper before putting it in?
        Have you tried rub rejuv. on the roller and separation roller?
        I'd start with just following the paper and see if you can narrow down the problem spot from start to finish and see what that turns up.
        • Dave10
          • Jul 2008
          • 197
          Tried everything with the paper. Don't think it's the issue. Edge is not marked. It comes all the way through the machine, it just multi-feeds. Also, this is a 4000-sheet side deck. It has no rollers or separators. Thanks foer the input, though.
            • 921
            PF 650 JAM32:
            Section: side feeder jam code 32: Misfeed in registration. Conditions: Feed switch 1 (FSW1) does not turn on within specified time <800 ms (586 ms) for 80cpm[8030]/1029 ms (586 ms) for 60cpm> of feed switch 2 (FSW2) turning on.
            Basically there's two feed switches and their timing is screwed up. Probably (just a guess here), the first page feeds and the roller catches a second sheet and they kind of take a ride together into the machine. Like a buddy system.
            You need to run maintenance item U031, among other things.
            If you don't have the pages let me know and I'll try and post them.
            • Dave10
              • Jul 2008
              • 197
              Cleaned clutches and the feed sensor. Problem solved. Thanks for the input.
                • 921
                No Problem. Glad you got it worked out.
