Have an Issue on a KM3050
  • Dr.silver
    • 38
    I am getting an error Message C7410. Once I turn on the machine it stays on the Please wait Screen for a minute or so, then it goes into a ready state. After that is show me a Error Code C7410. I reformated the HHD and flash the firmware with no luck. Any ideas??
    • 23009
    Reformatting the HDD probably won't help much in this situation. C7410 is a fault with the CRUM chip on the drum unit. Most of the time you'll see this code when there is no drum unit installed. If there is a drum unit and it is plugged in, then you'll have to replace the drum unit. =^..^=
    • grigarash
      had the same issue, when replaced service kit from 5050 instead of original 3050, just put back old chip on the drum unit and all gone.
