KM8030
  • TJ001
    • Nov 2009
    • 27
    KM8030
    Hi there.
    Can anyone help me. On the count report the meter reading is 4096384 but on the maintenance report the life count is 4190860. What is the difference ?
  • charly
    • 65
    maybe because the printer system ,the total counter account prints of copier and printer
    • Mark B
      • Jul 2006
      • 153
      On Kyocera machines the counts never match
      • aragul
        • Dec 2007
        • 128
        Any tests or reports that you do in simulation mode are added to the life count but not the customer's copy count. 95,000 is a pretty big difference though. I have one machine with a 40,000 difference (1.3mil total) because I spent a month testing an obscure J00 problem (missing a $1 ground plate). Sim U908 shows customer count; sim U928 shows life count.
          • 23009
          You beat me to it. Yes, copies performed in service mode, and reports do not appear on the Total Count report. I discovered this by accident. The first few machines I set up were in service mode during my initial testing. When I printed the final count I had (5) copies. I always run at least 50 per drawer, so with the DP it should have been closer to 300. =^..^=
          • peterepeat
            • 84
            It may have to do with double-counting larger-size sheets (11x17) for maintenance contracts.....
            Actual sheet-fed count vs meter/maintcontract count.
            • TJ001
              • Nov 2009
              • 27
              I also thought it's got something to do with copies in simulation mode but 95K !!!! Never !!! And the double count get added to the count report. I checked it. But thanks anyway to all.
              • NeoMatrix
                Senior Tech.
                • 3513
                Check the scanner and the fax counters to see if they total to the missing 95K pages.....?
                GDM
                • TJ001
                  • Nov 2009
                  • 27
                  There is no fax and they don't use the scan option.
