KM-5050 System Error CFA3E
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    [Error Code] KM-5050 System Error CFA3E
    Firmware didn't resolve, reseated HD connections and it worked...hopefully will save others from the shite I went thru. Venom
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
  • pjdbm
    • Sep 2007
    • 360
    you got off pretty easy then, good for you venom ! now you can relax and crack open a beer
    • Venom
      • Nov 2009
      • 765
      The pints went down pretty easy after this week...I actually called my wife to pick me up at the pub, probably the smartest thing I've done in a while, she dropped me at home and ended up going through a RIDE program on her way to the mall. Ya, I got off pretty easy, we haven't seen a HD fail on the Falcon 3, unlike the Falcon 2 which we had over 500 HD failures in 5 years (Kyocera acts like we were the only ones to see HD issues...lol)
        • 23010
        Thanks for the heads-up Venom. =^..^=
        • Gar the pilot
          Re: KM-5050 System Error CFA3E
          we just had a copier give us this code for the second time in 2 weeks, I was out for the first one and the other tech did a hard drive reset. but that was it. now its back and I would like to fix it. this client is 1 hour away at the far end of where we go. any fresh input on this??
          Thank You
          Gar the Pilot.
          • habik
            • 2013
            Any HDD issues or codes or machine taking ages to shut down or being sluggish on the 5050 goes with :
            Connector reseat
            HDD format
            Firmware re-flash
            Sent from my iDon't believe in marketing device using Tapatalk
            Firmwares HERE
              • 23010
              Thank You
              Gar the Pilot.
              When you decide to change the HDD, keep in mind that you'll lose your addressbook and network settings. And yes, you can back those things up ... but I certainly wouldn't trust a backup from a failing hard drive. I had a Toshiba recently that kept dropping the static IP. It cloned the addressbook and settings, and guess what? It didn't save the IP address. =^..^=
              • Gar the pilot
                i DID THE CONNECTORS, REFORMAT and then it worked yesterday ,.. this morning it came up with a C0640 my Client has open/closed front door and turn off/on and unplug Plug in copier and the C0640 won't clear this morning. Hadr drive time??
                Thanks, Gar
                • habik
                  • 2013
                  Thanks, Gar
                  Have you flashed it with latest firmware?
                  May need new HDD then
                  Firmwares HERE
                  • Gar the pilot
                    I did not have the frimware with me yesterday. My boss will have it for me today and I am taking up a hard drive too. I am hoping these use a standard computer hard drive, as he has a new 100G for me to use.
                    Thank You
                    Gar
                    • Gar the pilot
                      On our KM 3050 with c0640 and CFA3E it did have the latest frimware and I had to R+R the hard drive. every thing worked fine after that. got our HDD from Memory experts, BIG savings over Mita. client happy now.
                      • habik
                        • 2013
                        Memory experts are brilliant!
                        Firmwares HERE
