2126 envelope printing
  • shep
    • Sep 2010
    • 108
    [Misc] 2126 envelope printing
    i have a customer that is having problems with printing envelopes, you have to press ok on the machine, it says load paper in mp, press ok. the setting on the machine are set to envelope #10 and the print driver is set to envelope #10, with both set up the same way why is it beeping at me and having to press ok. its bugging to my customer and now that im working on it at the shop it is buggy me too
    • 23010
    According to the operators manual the MP tray is designed to hold (5) envelopes, then will prompt you to load more. It's just the way it's engineered. See attached:MP Tray.JPG
    • shep
      • Sep 2010
      • 108
      i got the problem fixed, you have to change the paper in the system menu for it to work, the function menu will not do it, its pretty dumb to run a diff paper of any kind is about a 10 step process. but it does not beep at you
