task alfa 181
  • tulipano
    • May 2010
    • 124
    task alfa 181
    salve ho un problema su due task alfa181 installate dopo 1000 copie i fogli escono ondulati il foglio esce come onde di mare agitate (quasi a fisamonica).le macchine sono nuove da cosa puo' dipendere?ho cambiato anche la carta ma il problema esce sempre grazie mille
    Hi I have a problem on two task alfa181 installed after 1000 copies of the paper corrugated sheets come out like waves rough sea (almost fisamonica). the machines are new from what may 'depend on? I also changed the card but the problem always comes out thank you very much
    • 22999
    • galumina
      • Sep 2010
      • 32
      check to see if exit rollers are grabbing the paper, I have seen it when the paper is not being pulled out because fuser is grabbing paper but the exit does not grab paper thus causing wavy paper. good luck
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
