FS-1128MFP Envelopes
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1883
    I know, I know, I've tried to get them to use the ink jet. Does anyone have any tricks to get them to work without wrinkling ? We've tried different types. They worked fine initially. The hotline had us replace the fusing unit, but the problem persists.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • kingpd@businessprints.net
    • 921
    Never had much luck with envelopes on copiers and printers. Switch to window envelopes, much nicer and easier to deal with.
    • madas
      • Aug 2008
      • 313
      Hi, Tony
      try these if you can get them in your part of the world.
      } Use DL Envelopes from Tudor and Officeworks DL Peel-n-Seal
      which are certified for Laser Printers. they have been the best to use. so i am told.
      good luck LOL
      madas
        • 23007
        Doesn't this one have envelope levers to reduce fixing pressure? =^..^=
        • tmaged
          • Oct 2008
          • 1883
          No pressure lever on these little puppies. I did get this gem from our ASM. The funny thing is, I inquired from the hotline since the 1300D, which the 1028/1128 is based off isn't off the sheet. They were not aware of these.
          Hope that helps !
          -Tony
          www.dtios.com
          • madas
            • Aug 2008
            • 313
            Hi Tony
            see attached for the pressure levers on the FS-1128.
            madas
            • tmaged
              • Oct 2008
              • 1883
              Thanks for that Madas ! I'll talk to the tech that went there. He called the hotline & I don't remember anything about pressure adjustments for the fuser. I searched "envelope" in the PDF and it never said anything about it. There is plenty in the end user guide, but nothing about the pressure.
              Hope that helps !
              -Tony
              www.dtios.com
              • DWise
                • 895
                Any updates on this problem?
                Do for one what you wished you could do for everyone. - Andy Stanley
                • tmaged
                  • Oct 2008
                  • 1883
                  As of right now, I handed it back to sales. I told him we could try it if they insisted, but it's in a law office with little old ladies. I don't think they want to go to the hassle that it will entail.
                  Our Kyo ASM & the hotline did not realize the pressure release levers were on the 1128mfp.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • DWise
                    • 895
                    That's pathetic!!
