component testing sensors
  • n25an
    • 1030
    [Misc] component testing sensors
    Has anyone here ever build a breadboard circuit to component level check a sensor switch? if so could you share the diagram...?
    if not does anyone here have the schematic for this sensor
    35327400 KYOCERA SENSOR
    the schematic would be more than helpful...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • aragul
    • Dec 2007
    • 128
    Why would you want to test a $2 sensor? Especially one that can be stolen from any parts machine made in the last 12 years.
    The wiring diagram says pin 1 takes 5V DC, pin 2 is a 5V input (on/off), and pin 3 is ground. But I nearly failed circuits so I can't help you with anything useful.
      • 22927
      For pin 2, 3.5vdc counts is the threshold. Under 3.5 = Off. Over 3.5 = On.
      Now that's some old-school troubleshooting. It's handy to know when that sensor has no diagnostics.
      Typically there are only two fault conditions: Dusty & heat failure (usually near the fuser). =^..^=
      • n25an
        • 1030
        Re: component testing sensors
        ok... I ran across this tonight... the photo sensor is called a photo interupter... and the link below should list how to test it...
        TESTING PHOTO INTERUPTER
        Now here is what it looks like from the outside
        from the inside
        as a schematic
        for more info go to the link I provided... vcc is 5v
