KM 4035e LCT 3 Missfeeds
  • yannii33
    • 121
    LCT #3 The papers stops between the feed rollers before it can get to the verticle transport from either left or right side. I cleaned both rollers and they are in good shape, it just stops Could it be the transport feed unit that sits right above that tray is faulty// Or is this some thing else Any help appreciated thanks
    • 23009
    Could this be a KM-C4035E?
    If yes, take a look at this post: http://www.copytechnet.com/forums/ky...code-12-a.html
    Noone can answer your other thread because the title ends in the word "print". We see the printable view without links. If you re-post that thread with a different last word, others can answer. =^..^=
