KM-3035 & NS-30G Scanner: Scanner doesn't save settings made in the web interface
  • Malcreatiure
    Hello!
    On a NS-30G Scannerboard (Firmwar
    e Version 2.64.5) some settings made via the web interface won't be saved. This is rendering the scanner part useless.
    Any Ideas?
    Perhabs a Firmware update might help. But I don't know where to download a new firmware and the IBVerUp Tool
    (mentioned here KYOCERA MITA | ServiceWorld | Techn. Support | FAQ | FAQ details - How can I update the firmware of an NS-30 scanner card? - laserprinter, printer, copier, multifunctionals
    Any hints?
  • aragul
    • Dec 2007
    • 128
    Are you using Firefox? The NS-30 only likes Internet Explorer.
    • luis8832
      • Dec 2008
      • 250
      You can get the tool from the kmaconnect website. This is the website for techs and sales, all the manuals and firmware can be found there.
      • Jules Winfield
        • Jul 2009
        • 821
        Exactly right. Sometimes if you're using an IE emulating plugin in Firefox it will work, but just use IE to be sure.
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
        • Malcreatiure
          yes, i use firefox. I will try IE and report back
            • 23010
            You'll be much happier with Internet Explorer. I've fought this same battle myself.
            Current NS30 firmware is 1.4.11, but I don't think that the Falcon II will allow SMB scanning, even with the upgrade. Email, FTP, or TWAIN only. =^..^=
            • kyocera.team
              • Aug 2010
              • 126
              agree try to use internet explorer and if not ... use u504 "Initializing the scanner" good luck
              • Malcreatiure
                IE 6 just did the trick.
                thanks! you guys were very helpful.
                  • 23010
                  The upgrade to scan card firmware 1.4.11 is supposed to resolve the problem with Firefox. Either way I'm glad that you got it figured out. =^..^=
                  • eagle123
                    • Nov 2008
                    • 7
                    I noticed that when i make a change in web interface and want to save it and at the same time the user is using the machine the setting isn't saved. Wait a few seconds and after user is ready you can save the settings well
