cs 5035
  • rbell12
    • Aug 2006
    • 83
    cs 5035
    we have a cs5035 w/srdf2, the lift up plate is stuck in the up position. is this a board problem or the solenoid/ the solenoid seems to be constantly energized. thanks for any help. rbell12
  • luig
    • Sep 2007
    • 52
    HI rbell, have you checked for voltage at the solenoid? This solenoid releases when voltage is applied to it. My guess, is that if you have voltage, it is a solenoid problem. If you don't, it is a board problem.
    Hope this helps.
    Luig
    • anthony123
      • 62
      solinoid issue
      Hello. My expereince with the old Mita machines is that there is always voltage supplied to th solinoids. The are activated by the main board applying a ground. Unplug both wires on the solinoid. With a volt meter hold the black lead to ground (Machine Frame) and check each wire for voltage. you should get 24VDC on one wire and 0VDC on the other. Mark them + and - Next set your volt meter to ohms or continuity connect the black Lead of your meter to ground and the red to the - solinoid wire. You should not have continuity. If you do its probably a pinched - wire or the main board ......Ant
