kyocera km-3225c black developer issue
  • jtymabel
    • Aug 2008
    • 164
    Just replaced the black developer and installed a new toner, machine is still reading toner low/add toner. I have bypassed the door interlocking to make sure the developer turns. It's turning and so is the toner feed motor. Any ideas. (i never initialized the developer, didn't know how to do it)
    • 23007
    The machine recognizes the new developing unit by the chip, and automatically performs a stir. So there wasn't a simulation that you needed to run.
    Are you sure it's "Add Toner", and not "Non-OEM Toner" message? This machine uses RFID chips to identify OEM toner cartridges.
    I suppose you could have some sort of a main drive issue, but you say that the developing unit is turning ...
    This machine is a little different than the KM-C4035E which has a black developer drive clutch, which can and does fail. The KM-C3225 is driven by the developing drive motor, which has a low failure rate. Did you turn the developing unit by hand to determine if the unit was hard to turn? I've come across a few units that have been exposed to heat that were very difficult to start turning. Once rotated through a few times, they worked OK.
    Just curious: What readings are you getting in U155 and U131, automatic? If you don't know how to run these simulations you really need to get a manual. =^..^=
    • jtymabel
      • Aug 2008
      • 164
      Thanks for the reply.
      The machine has Oem toner and it displays add toner.
      I have not checked the values for simulations mention.
      I not very familiar with this machine.
      I had to replace the developer because the old one was very hard to turn.
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        Remove k dev, hand crank the back in the same direction as the arrow.
        If no turning, k dev is ceased, replacemento.
        Edit: nvm. Its been covered, hard to see with blackberry lol.
        Idling colour developers are not healthy developers.
        • kyocera.team
          • Aug 2010
          • 126
          i face same this problem so many times the problem is in MPF drive ass'y check it
          • jtymabel
            • Aug 2008
            • 164
            going back to see this copier today...same issue...
            mpf drive..(developer drive?)
            thanks
            • jtymabel
              • Aug 2008
              • 164
              resolved the issue....
              noticed the bk developer had no toner. checked the bk toner supply motor and noticed that under strain (with the toner cartridge in place)the gear did not turn. one of the gears in the assy was not in place. replaced the toner supply assy for the bk and machine is back to normal.
              thanks for the help
