Vertical grey/black lines in background Taskalfa 250 Ci
  • Froggy
    • 14
    We have a CI 250 with vertical grey/black lines on the background. I have done sim 464/412/410, drum en developer cleaning and Registration en Calibration. But... no result.
  • kyocera.team
    • Aug 2010
    • 126
    as i understand ... did you check the transfer belt ?
    • Froggy
      • 14
      Black developer replaced and Firmware version 11. Problem is solved.
      • kyocera.team
        • Aug 2010
        • 126
        Congratulations ...
        • Dave10
          • Jul 2008
          • 198
          When this happens, what sometimes works is to rerun AC calibration for the black dev. Install firmware 11 and if you don't have a new black DV, try it the calibration.
          • ignacio.cortez
            • Jul 2010
            • 176
            I'm glad is not just me, I have a client with the same issue, HOWEVER, the Transfer belt is a Warranty Replacement because the old one had a line, in the same spot, about 1 week later I got called that the line was back, the machine is at Firmware V.11 and I have done all the calibrations, before changing the belt again, I want to make sure the cause is taken care of, I dont want to have to replace the belt again.
            • LNorris
              • Sep 2008
              • 646
              there is a new ta500ci troubleshooting guide that covers this issue
              • ignacio.cortez
                • Jul 2010
                • 176
                Humm, I have it, I think.
                But the Regional Kyocera Rep told me that it was no good LOL so I put it away LOL, I'll gave to pull it out of my archives and look up the issue.
