2126 Registration issues
  • shep
    • Sep 2010
    • 108
    i have a 2126 out in the field that every two to three weeks the registration is way off. by about 1/2 an inch. you can get the registration back to perfect and it will seem to run just fine. then it goes out agian. any had to deal with a problem like that on this machine yet. we have not put any new parts into it. i thinking starting with the transfer belt.. any other ideas to start with thanks guys?
    • 22999
    Can you reproduce the problem? If yes, can you try some internal prints, to determine if it's engine or scanner? =^..^=
    • shep
      • Sep 2010
      • 108
      yeah internal prints are bad, when i get there its bad and after registration its perfect. problem is there on prints and copies in color. black and white is always good
        • 22999
        Next question: On color copies/print that present the problem, is the color registration accurate with respect to the other colors? =^..^=
        • shep
          • Sep 2010
          • 108
          from top to bottom of the page the problem is equal at all parts of the page. from side to side it is not the left side of the page is a whole lot closer to normal than the right side of the page. as it moves right it gradually gets worse. starting at roughly 1/8in off to over a 1/4in at the far right
            • 22999
            It's not something mechanical like a transfer belt or registration clutch/motor. If each color is affected a little differently, and varies on the page (especially side to side) it's got to be something in the image processing or laser unit. I'm thinking laser. =^..^=
            • kyocera.team
              • Aug 2010
              • 126
              yes i think it's laser problem also ...
              • shep
                • Sep 2010
                • 108
                thanks guys that makes a lot of sense
                • ignacio.cortez
                  • Jul 2010
                  • 176
                  Have a similar issue on a 250ci, Client called me because Color Reg was way off, he tried to get it fixed following the instructions and it got worse, I went to the client and saw it for myself, I upgraded the firmware (then to V10) and ran a few calibrations, Color Reg was still way off, I turned Automatic Color Reg OFF and the Reg lines got closed, was able to get it calibrated, He called me last week with it off again, this time only a mm or so, got it Calibrated and Upgraded the firmware to V11, hope he does not call for that any longer.
