Doc Box & Job accounting.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Had encounter this scenario but never had the chance to verify.
    Job accounting is turned on, user sent files to doc box from PC, then go to machine to print.
    Does this print job get tracked twice? I cant recalled if the Doc Box menu is locked at the machine when Job Accnting is turned on.
    Idling colour developers are not healthy developers.
    • 23010
    It doesn't get counted until it actually prints.
    At least on the VoyagerE and Harrier series the eMPS menu is fully accessible with Job Accounting ON. =^..^=
    • ignacio.cortez
      • Jul 2010
      • 176
      That is correct, it does not get counted until it prints, Job Accounting and the Doc box are around the same area on the print driver, but they are managed a bit different, if you are just using Job Accounting, it will either let you print or not, unless you are selecting Private Job or something similar, they it will go to the Doc Box and Technically you can retrieve it from there (and I say technically, because I have a client that has not been able to get it to work (out of Crystal Reports anyways))
