taskalpha fax kit error code U01095
  • jrs157
    • Jul 2010
    • 22
    Anybody know what the code means ?
    Got this customer that intermittantly has fax problems. They insist it is the machine but when I am there it xmt/rcv fine
    Except for one time on a 5 page fax being sent. The # dialed and dialed as the office phones also rang and were answered. Finally, the machine gave up saing busy and showing an error of U01095. I went to another machine in a different part of town,same model , dialed the fax and sent 5 test fax sheets no problem. I haven't heard back yet if they had their phone lines cheked out yet. I don't really want to go through the paperwork hassle of swapping out the fax kit but that will be my next step. See if their fax kit checks good on another machine while they dial away on their new kit
    AN ounce of prevention is worth a pound of obscure
    spare screws
  • jrs157
    • Jul 2010
    • 22
    It s a task alpha 420i
    spare screws
      • 23010
      Fax Communication Error: Transmission in G3 mode was interrupted by a signal error. No relevant signal was received after transmission of a PPS (Q) signal during phase D of transmission, and the preset number of command transfers was exceeded.
      This is G3, like manufacturer (Kyocera to Kyocera). It's an error as a result of poor line conditions. =^..^=
