taskalpha 300i
  • PANG
    • 104
    taskalpha 300i
    hi ! i have problem with this new machine show F000 intermitent and system error after that shown c0640. i had done sim 917 and reformatt HDD. But the error code F000 still appear and c0640 not shown . Anyinput are welcome .THANks.
  • luis8832
    • Dec 2008
    • 250
    flowchart
    I am sending you this flowchart from the kyocera website. This should help you out with your problem. Let me know how you make out. Good luck
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • kyocera.team
        • Aug 2010
        • 126
        F000 Operation panel PWB communication error as the manual
        try to update frimware first if it's ok that's fine if not change the DIMM and upgrade the frimware again
        good luck
        • PANG
          • 104
          sorry for late reply , try to recable connector on operation panel so far okay .
          • Wayne
            Re: flowchart
            Thanks it helped
            • copyguy1642
              • 22
              Re: taskalpha 300i
              Does anyone have the seperate firmware files they talk about? Besides Kyocera?
                • 22929
                Re: taskalpha 300i
                Only going back to version 7.0 of the firmware. You'd have to upgrade 7 or 8 times to get to current firmware. =^..^=
