KM 4050 Add Toner
  • Ferdy
    • Sep 2010
    • 22
    KM 4050 Add Toner
    We have a KM-4050i that keeps trying to add toner. The toner morter seems to working (or at least we can hear it turning). We have tried replacing the toner cartridge and it still wont tone up. I'm not too familiar with the 4050...any ideas on what i can check?
    Thanks for the help!
    • 22999
    Is it a TK-717 cartridge? The Type A cartridge used in the Falcon II series looks identical, but the coupler is different. =^..^=
    • Ferdy
      • Sep 2010
      • 22
      Hi Blackcat: It is a TK-717 cartridge. Should I be using something else?
      • vstar
        • Aug 2007
        • 176
        TK-719
          • 22999
          Nope. TK-717 is the right one. I've heard rumors of problems with the timing belt drive that drives toner add. But it's no fun to access.
          You might try removing the toner cartridge, key the front door, then run U130 to watch the coupler drive.
          • kyocera.team
            • Aug 2010
            • 126
            check toner drive ass'y ...i encountered in KM 5050 there's PARALLEL PIN maybe it fall down ...
            • Ferdy
              • Sep 2010
              • 22
              I was reading another thread and found out that the Kyocera 4050i uses a different toner coupler. I guess the 4050i was used for Ikon, and takes another type of toner? Have you heard of this? Is there any way to change it over to a standard 4050?
              Thank you!
                • 22999
                Correct. There is a different drive coupler for the Ikon version. I've read the number someplace ...
                We're a Copystar dealer, and I believe that the Kyocera and Copystar use the same coupler (302GR31010). Can anyone confirm that?
                That's all you need for the conversion. But again, it's not much fun to access. =^..^=
                • Zackuth
                  • Aug 2009
                  • 448
                  I have "fixed" these by gently pulling the toner gear frame slightly forward. The replacement for this drops the gears by .3mm and it is not fun to get to.
                  If at first you don't succeed, redefine success
                  • kyocera.team
                    • Aug 2010
                    • 126
                    yes it's same in kyocera 2GR31010 coupler ...
                    • Ferdy
                      • Sep 2010
                      • 22
                      Hi Vstar, Is the TK-719 the toner model number for the 4050i (the Ikon version)?
                      Thanks!
                        • 22999
                        TK-719 is the Copystar number, and that will work also. Same toner, same everything, just a different number.
                        • Ferdy
                          • Sep 2010
                          • 22
                          Hi Zackuth,
                          Do I pull the toner gear frame towards me straight or down towards me?
                          Thanks,
                          • Ferdy
                            • Sep 2010
                            • 22
                            Hi Blackcat,
                            If I use the TK-719 will i still have the same problem because the customer has the Ikon version?
                              • 22999
                              Yes sir. And the "pulling down" only works for couplers that are capable of engaging. =^..^=
