250ci background, *another one
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    full page, 2mm interval, very even.
    Not drum, not charge, DLP? primary transfer roller?
    the troubleshooting guide suggested tweak had no apparent effect.
    edit:
    2mm over 8 1/2" is about 215.9, divided by 2 is 107 ish. Guesstimating imaging process takes 1 sec for 30ppm machine, and 1 sec fro paper transport. That gives me about a frequency of the AC.
    Assuming its AC, which component would cause that?
    no, I tried to tell my doc I'm crazy.
    and uh, springbreak, things are slow.
    Idling colour developers are not healthy developers.
    • 23009
    So, your image defect repeats at 2 mm intervals, or ~107 repetitions per page?
    Well the drum will be ~95 mm intervals.
    Primary charge will be ~38 mm intervals.
    For starters, what colors are affected by your defect, in sim U089, Gray test patterns? Can you attach a scan?
    I suspect that you've got a charge loss affecting mainly one color, and the source could be developing bias short or drum ground loss.
    I doubt that it would be a drive problem because of the short interval. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      K DLP, and yes I believe its the bias as well.
      Its electrical for sure.
      *not on the site, I'm the phone support for this one.
        • 23009
        I would try the black developing drive motor first, due to it's history of problems. Second choice, black developing unit. I would be nice if you had a scrap black developing unit that you could swap in for diagnostics.
        You know the same motor is used elsewhere in the main drive. As a test you could switch the black developing drive motor with the black cleaning motor to see if you can change the defect.
