km 3850 light image
  • maya
    • Aug 2010
    • 12
    [CQ] km 3850 light image
    km 3850, 3 yearfs old, drum and developing roller recently replaced for the same problem,
    copy will light only in center area . before replacing the developing roller, i cleaned it , some kind of toner coating like shining found above the roller . after cleaning, it was working ok( not 100% ok) better than before. but again same problem started, then only i replaced drum and developing roller.
    2 months after same problem started . we have three KM 3850 machine in same place. i inter changed the drum, dev units... nothing helped me.... infact other machines also having same problem,
    any suggestions please....
    A bad workman blames his tools
    • 23010
    You must have about the only Kyocera Mita FS-3850 ever sold.
    I found hundreds of references to Epson Stylus 3850, Kip 3850, Toshiba BD-3850, Sharp FO-3850, and Ricoh Aficio AP3850.
    I couldn't even find a sales brochure. =^..^=
    • maya
      • Aug 2010
      • 12
      sorry black cat... it is KM 3650 W .
