Taskalfa 300ci cassette 1 error
  • Realtech
    • Oct 2009
    • 103
    One of our machine suddenly gave an error massage" cannot print from cassette 1 due error" I cannot find this message in the operation manual neither in the services manual.
    In the services log i cannot find an error related this problem.
    I remove the paper cassette and found a paper between the rollers futher I insert the cassette 1 but still the error appear. I turn the machine off and on still the error messages.
    Any Idea?
  • aabarnes1
    • Mar 2009
    • 620
    Any Idea?
    Reset disable mode in sim 969
    Grant me the serenity to accept the things I cannot change.
    • Eric1968
      • 2458
      SIM 906 = Reset Disable Function (969 doesn't exist).
      When a jammed paper is blocking the lift mechanism, this error can occur.
      • aabarnes1
        • Mar 2009
        • 620
        RELAX man, slip of hand on keyboard. You're correct 969 do not exist - so no harm done!
        • Eric1968
          • 2458
          I know it's a slip of hand on your keyboard, did not mean to be rude.
            • 23009
            Most likely you've got a C1010 lift motor error stored on the error log. Sometimes the customer just loads the paper wrong. Sometimes the plastic shaft of the lift motor twist, binding the spring loaded coupler. Sometimes a shorted lift motor toasts the drive circuit on the engine PWB.
            In any case, the first step is to clear the error in U906.
            If it's the last one, replace the lift motor & engine PWB as a set. =^..^=
            • Mohammad.anwar
              • Aug 2010
              • 11
              print event log then check for error code c1010 or c1020 then rum u906 then check the cst if working or not ...if not check the female connector for cst i think there's an paper dust inside this connector if no paper dust remove cst and check manually if the motor moving slowly open the back side cover and check motor lift connector if there's 24v but it's should going to 0V after 15 secs if not going to 0V ...sorry you have problem in your engine PWB
              Dont measure yourself what has been done untill now , but must be compared What You Can Achive with Your Ability
