kyocera C3232 can't ping it
  • mrfuser
    • 1617
    Okay, we reset the network settings, we can ping the SCAN portion and bring the SCAN portion up on internet explorer, but nothing on the PRINT side. We can't ping the print IP nor can we discover it, or bring it up on internet explorer.
    Any ideas?
    Kelly
    • 22999
    When you print the status page what address is listed? DHCP: Off/On?
    I usually default DHCP to On during setup, so that DHCP can pick up DNS1, DNS2, Wins, Domain Name, etc. But every once in a while I've come across a network with DHCP Off. Only preassigned address allowed.
    On 35+ Voyager and VoyagerE machines I've never had a bad print card. I've had to power cycle a couple machines to get them to be recognized on the network. I've mis-entered IP address data before.
    Did you attach your laptop to that specific network drop to see if it pick up an address? If it doesn't, DHCP could be Off, you could have a bad cable, maybe an unconnected network port, maybe a bad switch port, etc.
    Or you could crossover the MFP directly to your laptop. If you still cannot get access to the Command Center, perhaps you do have a bad print card (but I doubt it). =^..^=
    • pjdbm
      • Sep 2007
      • 360
      went out today with a no print on kyocera 420i, could not ping it either, I reset router/machine and checked out all connections...
      Turned out to be the hub! unplugged and bam, she started pinging and printing.
      Wish I was still in the analog days where we did not have to deal with this shit...
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        On the odd cases, especially in none professional environments, you get 2 routers. If one of them's DHCP funciton isnt turned off, something will [censored] up. If both router has 192.168.1.# setup, it will [censored] up too.
        tmage, correct me if I'm wrong.
        Idling colour developers are not healthy developers.
          • 22999
          That's a good point J. I have an IT contact that came across this the other day. Two routers handing out addresses, depending on which was faster on the draw. It took weeks to find it. And it was an "enterprise" environment. Sad really ....
          • Aries_1
            • 42
            Keep in mind on Kyocera models only, certain models will DISABLE the NIC permanently if it realizes its not plugged in. (i.e. - its working - then you unplug/replug - no more link light). So make sure you are restarting the machine often during your troubleshooting.
            • correo.tony
              • 72
              Connect a laptop with a network cable directly to the printer nic and run the web explorer with the ip adress that appears in the status page,
              Bye !
              • Raymondd
                • Jan 2008
                • 108
                I've had some issues with Bonjour being turned on??? In a PC environment...
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  set your laptop's lan setting to
                  static
                  IP: 192.168.1.2
                  mask: 255.255.255.0
                  gateway 192.168.1.1
                  machine static IP to 192.168.1.3
                  plug the cable in both, open up a browser, type in 192.168.1.3, you should be able to see command centre.
                  or
                  hit "printer" button on the left, is it offline? if it is, hit "go" again and see what happens.
                  2nd OR
                  you know the printer port is hidden in the cover, no? 2 Ports, 2 cables.
