KM6030/Utax 1060 lines on prints and copies ( digitally generated)
  • aabarnes1
    • Mar 2009
    • 620
    This machine with 660 k and a maintainence kit to it's name is producing very thin pencil like grey lines from the top of the page to the bottom regardless of orientation. It looks like background until you look very closely. Then you can see the individual lines. Aswell as this when you print off say the count report, on the report where it gives serial number, count etc there is a ghost image of the text about 1 cm right below it but faded grey. This fault is repetative but intermittent and it's wrecking my head !!!!!!!!!!!!!!!!!
    Grant me the serenity to accept the things I cannot change.
  • Metalvoc
    • Sep 2008
    • 155
    I haven't seen anything like this on a Kyocera, but I had a Panasonic once that was printing digital lines / patterns in the background. I tried cleaning and re-seating connectors and memory, but ended up replacing the memory. That resolved the problem. Don't know if this helps, but you might try cleaning and re-seating the memory.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
      • 23010
      Let me see if I've got this right ...
      Lines appear on internal prints.
      Lines appear on copies top to bottom (crossfeed) on LTR paper.
      Lines appear on copies top to bottom (feed direction) on LTR-R paper.
      It makes no sense to me. It's obviously not a scanning problem since it's on internal reports.
      My guess is that those lines are always either crossfeed or in the feed direction, and that it's related to the laser and/or the laser wiring harness. There is an update to the laser wiring harness ... maybe it's related. =^..^=
      • aabarnes1
        • Mar 2009
        • 620
        Heloo chaps, turned out to be the HDD, a friend of mine had it once and advised me of same. Changed it this morning with exact same, did sim 21, 989 and 24. worked like a dream. Thanks
        • Nisar235
          • Nov 2009
          • 13
          give saltion
          copystar 6030 reset digital meter counter
          • aabarnes1
            • Mar 2009
            • 620
            Re: give saltion
            What simulation mode/code is that function in please?
            • kyocera.team
              • Aug 2010
              • 126
              Re: KM6030/Utax 1060 lines on prints and copies ( digitally generated)
              replace main charge
