I have 2 TA 400CI that are getting smudges on the copies
, when you pull the transfer unit there is waste toner piled on top of the black drum unit. I have cleaned the waste system, replaced the black drum unit, black developer unit, transfer unit. upgraded the firmware to level 11, installed the spring mod in the waste tube. Am going to replace the waste motor (as per the recent bullitin on waste motor error code note: I am not getting error codes). I am trained on this machine and am also going to post a message to Kyocera just trying to get as much info as I can.
