TASKalfa 300ci light copy
  • Luong Nam
    • Oct 2009
    • 49
    Hi
    Please, help me
    My TASKAlfa 300ci has light copied issue. I already do U089 but it still has this problem.
    Thanks in advance
  • tech07
    • Aug 2008
    • 410
    Please provide more info....color copiers ?? B/W copies? Need more details about your symptom
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      u89 is not meant to "fix" anything, it shows you the symptoms at the core.
      Are all CMYK fainted the same amount? Any patterns showing?
      Idling colour developers are not healthy developers.
      • Luong Nam
        • Oct 2009
        • 49
        It's images like this
        The first image is a orginal and the second image is a copy.
        TIA
        • Zackuth
          • Aug 2009
          • 448
          If this is just on copies, I'd clean the scanner mirrors and DP glass.
          If at first you don't succeed, redefine success
          • Metalvoc
            • Sep 2008
            • 155
            Also run your auto gray adjustment. It would help to know if color prints are light as well.
            I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              I really have a hard time seeing issue with the picture. The right side is lighter but still good.
              If the original can be printed, i'd just print.
              • gneebore
                • Feb 2010
                • 555
                Also run the drum refresh from the operator controls/adjustment. I have had that make a world of difference enough times that I have started teaching the key operator how and when to do this.
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  If the original is glossy, wouldn't the effect be like that as well? With too much light per dot?
                  Be nice to see different samples
                  • LNorris
                    • Sep 2008
                    • 645
                    change your copy settings. you can change resolution and density to correct this. we went thru this in school on the TAs. if it is what we found, its not mechanical. just the settings need to be changed for that copy job.
                    • Luong Nam
                      • Oct 2009
                      • 49
                      This's a print report from TASKalfa 300ci
                      Thanks for your help and supports.
                      • PANG
                        • 104
                        try to clean lsu.
                        • jmaister
                          certified scrub
                          • Aug 2010
                          • 755
                          If you could provide the Service Status Page that'd be nice too, if not, could you post the coverage ratio? u131 numbers are a bit low.
                          • Luong Nam
                            • Oct 2009
                            • 49
                            U131: Adjust toner sensor control voltage
                            - Manual adjustment: 116, 116, 116, 116
                            - Auto adjustment: 172, 166, 166, 166 and 150, 139, 136, 132
                            - Operation mode: Auto
                            Machine status is inside a print report file.
                            TIA
                              • 23009
                              I would do a developer refresh, U464 > AC Calibration > CMY to On > Start, then a Color Calibration. In that order. =^..^=
