Error Code C-4100 on Kyocera/Copystar
  • helpmepleaze
    • Mar 2010
    • 16
    [Error Code] Error Code C-4100 on Kyocera/Copystar
    What is this Error Code C-4100for Kyocera Copystar?
  • Zackuth
    • Aug 2009
    • 448
    It's a laser error. You might end up having to replacle the laser. You might want to try the charge grid first. I have had that happen on a KM6030, changing the charge grid fixed it.
    If at first you don't succeed, redefine success
      • 23008
      What model? =^..^=
      • Jude
        • Oct 2009
        • 256
        check the grid and perform SC906
        • Jude
          • Oct 2009
          • 256
          where in the Bronx?/
          • JustManuals
            • Jan 2006
            • 9838
            Just Manuals | The Internet's largest selection of manuals | Instant Downloads
            Paul@justmanuals.com
            • helpmepleaze
              • Mar 2010
              • 16
              What model? =^..^=
              CS-8030
                • 23008
                Originally posted by helpmepleaze
                CS-8030
                It could be caused by:
                1) Charge loss (developer bias contact, transfer bias contact, drum ground)
                2) The laser harness. There is a new style, and re-routed.
                3) Possibly even the laser unit, but unlikely.
                Note: Conductive grease can be used on the transfer bias contact. Conductive grease cannot be used on the developer bias contact.
                • Geo
                  • 662
                  Blackcat
                  Is that All conductive grease or can a good carbon based grease be used on Dv bias contact.
                    • 23008
                    Originally posted by Geo
                    Blackcat
                    I don't know of any conductive grease that is suitable for the developing bias contact. If you use conductive grease eventually you start getting blank bands crossfeed, fading in and out. =^..^=
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      Re: new harness and route, pack a lunch.
