km 5050 and C0130 AND C0640 ERROR CODE
  • n25an
    • Jul 2008
    • 1030
    [Dead] km 5050 and C0130 AND C0640 ERROR CODE
    Ok...
    I have a km 5050 that generated a c0640 error code... Bad hard drive or bad main board... He carried out a main board and a hard drive from a working machine to test out the parts... By the time he was done... The machine was displaying a c0130 error code. He had moved around the eeproms... The customer currently has a loaner machine... My question is where do i go from here... Is it possible to just reprogram the eeproms and if so how do i go about this... Any help would be appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • Masterchief
    • Apr 2011
    • 280
    C0640 is a HDD failure, you dont have to swap boards or thee eproms.. Just buy a new HDD and replace it, the only issue lost maybe is the info on the old hdd.
    On another note the machine will still prob work without the HDD for the time being, but the ARDF etc will not be useable
    Masterchief
    sigpic
    • JR2ALTA
      • Feb 2010
      • 2033
      Hear me and hear me good. Load firmware via CF card near ethernet port. USB firmware won't work with these codes.
      Falcon 3's won't work unless engine and main firmware are on the same level, that's why your swap didn't work.
        • 23009
        Agreed. Replace HDD. Reformat the hard drive. Reload firmware. That should resolve your codes. =^..^=
        • Mr.Rain
          • Mar 2011
          • 6
          fomat HDD
          I am format HDD from PC
          • n25an
            • Jul 2008
            • 1030
            thanks... issue resolved...
            • Cooperman
              • Oct 2012
              • 2
              Re: fomat HDD
              When formatting the HDD from a PC, which file system do you use? FAT32/NTFS etc?
              thanks
              • JustManuals
                • Jan 2006
                • 9838
                Re: km 5050 and C0130 AND C0640 ERROR CODE
                Paul@justmanuals.com
                • Mr.Rain
                  • Mar 2011
                  • 6
                  Re: fomat HDD
                  thanks
                  File system does not matter, once installed on the machine you want to format the internal command.
                  • Jude
                    • Oct 2009
                    • 256
                    May I use any IDE 40 GB hard drive or does it have to be Kyocera? What are compatibility specs?
                    • Mr.Rain
                      • Mar 2011
                      • 6
                      I installed the last 250 GB HDD
