KM 6030 jam codes 65 & 66- constantly
  • habik
    • 2013
    #16
    The fuser gears typically present with J40, J41, J42, J43, J44.
    Jams in the J60's are in the duplex/inverter section. =^..^=
    Yes you are right! I did have however one incident where it would jam in Duplex only. If I have some time tomorrow, I'll try to simulate it.
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • Schluken
      • Sep 2014
      • 13
      #17
      Re: KM 6030 jam codes 65 & 66- constantly
      This looks like an old thread so I will make this quick. Under the bottom tray of the duplex unit is a switch. Replace that switch and check the next one down the line for cuts in it. I see these a lot in this model and taskalfa 620's. Replacing the upper roller of the duplex unit will only help with j-60 and j-62.
      • Tonerkiller
        • Oct 2012
        • 668
        #18
        For the j10s clean the oneways in the feed unit and replace the sep arbor
