KM 6030 jam codes 65 & 66- constantly
  • aabarnes1
    • Mar 2009
    • 620
    Have checked all motors and switches in sim 31- replaced dupcsw 1 as a result, now getting a near constant jam 65 or the odd 66. Put dup in other machine and error followed.
    This is an ongoing fault and it's wrecking my head- assistance greatly appreciated-thanx
    Grant me the serenity to accept the things I cannot change.
    • 23006
    That's an unusual jam code. I see lots of J10, J11, J12, J60, J61, J62, J63, J81, J82.
    I can't recall a single instance of J65 or J66. Perchance, while you were fiddling with the duplex feed switch (the one reflective sensor), did you leave the bottom of the union connector un-done? I just experienced this today.
    Were you able to find all the duplex sensors in simulation U031? It took me a while. =^..^=
    • Zackuth
      • Aug 2009
      • 448
      Underneath the switchback cover ther is a plastic roller for the switchback roller. Remove the plastic roller, clean and lube the shaft and the area on the roller the shaft fits in. I have had a lot of success clearing duplex jams by cleaning these areas.
      If at first you don't succeed, redefine success
      • Mark B
        • Jul 2006
        • 153
        Yes clean the idler roller shaft if it is not spining freely and also replace the roller under it, the diameter gets smaller in time.
        • aabarnes1
          • Mar 2009
          • 620
          i am aware of the switchback assembly causing jams around 1million+ copies and have swapped it. i basically stripped the duplex down and cleaned/lubricated all bushings/shafts etc.Still having the jams. As i mentioned the most jams are jam 65, the 1st conveying switch. This has been swapped out. All sensors, in accordance with sm diagrams have responded in sim31, as have all motors in sim 30. I'm really baffled with this one
          • aabarnes1
            • Mar 2009
            • 620
            I'm not sure what you mean when you say 'union connector'. And yes, I can find all sensors in sim31, they all respond correctly. It's a strange one!
              • 23006
              A union connector fits in the frame or just inline with male pins, with female connectors on each side. =^..^=
              • qbert64
                I've had a couple 6030's with bushings in the duplex unit that the grease turned into tar and slowed down the drive and caused constant jamming. There is one in the finisher to keep an eye on also which causes finisher jams/service code.
                • ignacio.cortez
                  • Jul 2010
                  • 176
                  Ya check the switchback roller, when it turns conical (even by a small difference) will give you the 66 and 65, only other thing I can think of, check your guides just past the switchback roller, if they are just a bit off, will cause the paper to slightly skew and cause the jam (I cheated the door and took the ADU cover off and watched the copies with my trusty flashlight until I saw the cause, once I adjusted the guides the client stopped calling (of course, now that I am thalking/thinking about them, they're prolly going to call within the next couple of days. (Hope to replace with a 5550 (or higher) (though I'm not a big fan of them, not tech friendly for my taste)
                  • habik
                    • 2013
                    as "Ignacio" suggested change the Duplex Roller it causes 90% of all 60's codes. It actually wears out by a 0.1mm per 100k..mines were going arround 700k and I would not bother to clean them. Even the shaft for the duplex switchback nylon pulley gets sometimes hammered and it needs change or buff on lathe. I change Duplex roller and give real good clean to the Switch back pulley shaft and make sure the pulley ain't worn out. Also check the casing for the pulley, that has sometimes scruffy edges arround the hole befor its bent by CNC machine.
                    Yeah and good quality high viscosity lube on the pulley shaft.
                    Happy 700k.
                    Firmwares HERE
                    • milldew
                      • Mar 2010
                      • 22
                      Re: KM 6030 jam codes 65 & 66- constantly
                      I'm having the same problem with Taskalfa 620, have changed shitchback roller and a few sensors to no avail. It is intermittent now, Jam 65 every time.
                      The paper always comes through switchback and past the conveying switch #2 and stops. I will try the guide adjustment, the one screw in the middle
                      of the side adjustment area ,next. It is centered now, not sure why they have an adjustment screw there.
                      • habik
                        • 2013
                        Check fuser transport conveyance gears.
                        Sent from my iDon't believe in marketing device using Tapatalk
                        Firmwares HERE
                          • 23006
                          The fuser gears typically present with J40, J41, J42, J43, J44.
                          Jams in the J60's are in the duplex/inverter section. =^..^=
                          • ClarkIR
                            • Oct 2013
                            • 74
                            i dont mean to hijack this thread but we have two 620i's that will not stop jamming in tray 1 (J10). Weve replaced the rollers and Mylars countless times, but we cant seem to put our finger on what is keeping this a problem.
                              • 23006
                              So start a new thread. =^..^=
