Jam code 31 on TA 500ci
  • Jules Winfield
    • Jul 2009
    • 821
    [Jamming] Jam code 31 on TA 500ci
    This machine jams every print at the transfer belt unit area. I checked switches, motors, etc... The transfer belt unit is new. The paper is z-folded and not quite making it to the entrance of the fuser. Does this sound familiar to anyone? I'd love some help on this one.
    Thanks...
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
  • ss12
    • Jul 2008
    • 289
    There is modification for this which requires fitting additional mylars to solve your problem
    • Jules Winfield
      • Jul 2009
      • 821
      Are you talking about the mylars that come with a new transfer belt unit? They mount on the transfer belt unit in between the little metal claws with the white plastic wheels that look like little sprockets, right? Yeah, I did that when I replaced the transfer belt unit. Just for clarification, the machine was having the same issue prior to the transfer belt unit being replaced. Any other ideas? Come on Blackcat, don't hold out on me bro...
        • 23010
        Usually the transfer belt is ripped the shreds by the time the Z-folding happens.
        Did you turn the transfer belt assemby by hand, then with the paper conveying motor (U030). I don't see why you couldn't key the left door and run U030 to watch the transfer belt rotate.
        I won't insult you by asking if you removed all the little foamy padding things and the tape. I have good reason to believe there is a thread on Copytechnet for just that, though.
        You might take a look at the mylars at the bottom of the left hand door. I've seen where those get mangled, and can cause wrinkles before transfer. Unfortunately, to get a good look at those mylars you'll have to remove the door. It's inconvenient with the spring loading & cable supporting the door, but manageable. =^..^=
