service bulletin serial # incomplete
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Its for the waste toner motor, just dug it up for review. The serial range doesn't cover much earlier production dates.
    Anyone else found that odd, or is there explanation for it?
    For the 500ci series.
    Idling colour developers are not healthy developers.
    • 23010
    I consider it to be an oversight. We've changed dozens of waste toner motors on the VoyagerE Series for the same reason. The old style motor will eventually short out, and blow the driver circuitry on the engine PWB.
    We went through and wholesale updated all the Voyager and VoyagerE machines. It beats replacing engine boards. I haven't replaced an engine PWB in 6 months. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      Did u have to purchase extra motors? We're missing a fair amount sent by km.
      Edit: pls read the bulletin carefully, and contact km direct. This is expensive stuff.
        • 23010
        Yes, we purchased more motors, and it's well worth it. =^..^=
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          We are being told that the list is smaller than originally thought. I just think that they don't have as many replacement motors as required.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            the machines that were produced in the first six months of production is NOT considered? hmmmm, very nice.
