Problem with printed colours KM-C3232e
  • drazen7777
    • Sep 2010
    • 40
    doc20110608081959.pdf
    Hi all
    I would like to ask if anyone had a problem like following with this device .
    The problem is that blue and black print are pale on first half of print and about second half(horizontal) of the print rapidly repaired (scan to pdf attachment - the black is not seen on the scan but it looks like the blue and gray sample) and there are olso visible vertical lighter streaks. If someone had a similar case So that tells me some hints, I tried to replace the drum and transfer belt, cleaned all connectors. The yellow and red color does not notice these signs.
    Technician -- a person who fixes the mistakes made by engineers.
    • 23008
    I would do the following:
    1) Clean the primary charge rollers (use towel & minimal amount of glass cleaner).
    2) Clean scanner optics.
    3) Clean laser slit glasses (System Menu, V to pg 2, Adjustment & Cleaning, Laser Scan Cleaning, Execute)
    4) Turn Off U467 Auto Color Registration. Exit service mode.
    5) Turn On U467 Auto Color Registration. Exit service mode.
    6) Perform Color Calibration (System Menu, V to pg 2, Adjustment & Cleaning, Color Calibration, Execute)
    7) Perform Color Registration (System Menu, V to pg 2, Adjustment & Cleaning, Color Registration, ... follow prompts)
    8) Perform Gray Adjust (System Menu, V to pg 2, Adjustment & Cleaning, Gray Adjust, ... follow prompts)
    ... then tell me how it looks. =^..^=
    • drazen7777
      • Sep 2010
      • 40
      Thanks for the tips , will try them , machine is in the field so i will do that when i go to the customer. I tried clean slit glasses , colour calibration and gray adjust , didnt help .Will try other stuff that you mentioned .
      Regards
      Drazen
        • 23008
        A developer refresh, sometime before #4) would be nice too. =^..^=
        • drazen7777
          • Sep 2010
          • 40
          Tried your tips , but didnt worked , still the same. Will bring kyo to the service to check it out.
          Regards
          Dražen
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
            Paul@justmanuals.com
