doc20110608081959.pdf
Hi all
I would like to ask if anyone had a problem like following with this device .
The problem is that blue and black print are pale on first half of print and about second half(horizontal) of the print rapidly repaired (scan to pdf attachment - the black is not seen on the scan but it looks like the blue and gray sample) and there are olso visible vertical lighter streaks. If someone had a similar case So that tells me some hints, I tried to replace the drum and transfer belt, cleaned all connectors. The yellow and red color does not notice these signs.
Hi all
