KM 3650W light image only in center area
  • maya
    • Aug 2010
    • 12
    [CQ] KM 3650W light image only in center area
    KM 3650W light image only in center area... in the test print no 1... the dots and lines very light only in center area...
    we changed the drum, developing roller, drum cleaning roller .... copy quality improved ,but still light images in center area.....
    we have around 10 machines ... all are having same problem.. i hope its common problem in KM3650W . any one face this problem... please help us.......
    thanks in advance.....
    A bad workman blames his tools
  • Mark B
    • Jul 2006
    • 153
    I have delt with this problem. You have to rebuilt the dev unit. There is a pm kit for the dev unit use it.
    • maya
      • Aug 2010
      • 12
      cai i get the part code and modification Bulletin for the same????
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
        Paul@justmanuals.com
        • luis8832
          • Dec 2008
          • 250
          info on 3650w
          here is the new model product info/it has the numbers for the pm kit you need now and in the future
          • jewen25
            • Mar 2009
            • 197
            i think "MARK B " is right
            ERROR HELP ME AND HELP YOU
            • kyocera.team
              • Aug 2010
              • 126
              are you using original toner
              • c.olivieri
                • Sep 2010
                • 8
                Re: KM 3650W light image only in center area
                Anche io ho avuto gli stessi problemi .
                Ho notato che scaldando con un asciugacapelli per 10 min la parte della cassettiera dei rulli il problema non si presenta.
                I too have had the same problems.
                I noticed that the warming with a blow dryer for 10 min roll paper deck assy , the problem does not occur.
                excuse for my english
                Carlo from Sardinia
