ERROR CODE (0x1101) KYOCERA KM5050
  • SoCal Office Systems
    • Apr 2011
    • 17
    [Error Code] ERROR CODE (0x1101) KYOCERA KM5050
    Does anyone know what this code means?
  • dogg_man
    • Jun 2011
    • 48
    Do you get this when you scan to file or email?
    Then its a
    Error: Host name
    Wrong IP address or Host name your trying to scan to.
      • Apr 2011
      • 17
      ya thats what it was, do you by any chance know where I can get the ftp utility for kyocera machines?
        • 23009
        It depend on what you're trying to do when you get this error.
        Could it be a U01101 or E01101, which is a fax communication error (function of the unit differs from the NSS signal)? This is usually what you get from poor phone line conditions.
        Could it be a Send Email 1101, which is a problem with the SMTP server communication? Usually it's just an incorrect address programmed.
        Could it be a Send FTP 1101, which is a problem with the destination server address?
        It would help to know how you got this error. From a scan report, from a fax report, from the display screen, ...? =^..^=
          • Apr 2011
          • 17
          Do I need an FTP Server from Kyocera in order to make scan to ftp work. I am always used to Konica Minolta Ftp Server.
          • dogg_man
            • Jun 2011
            • 48
            I never tried the Konica Minolta FTP server software on anything other than Konica stuff.
            However a quick google search and http://usa.kyoceramita.com/americas/...tility3169.exe
            Good luck
              • 23009
              Yes you need the ScanFile Utility to be able to scan to FTP. You can use Scanner File Utility version 4.11.04 or version 3.17.11
                • Apr 2011
                • 17
                I download this scanner file utility and I got check what information the user needs in teh address book and nothing seems to match up. Untitled.jpg
                  • Apr 2011
                  • 17
                  I also get this.
                    • Apr 2011
                    • 17
                    uggg! now i cant remove this scanner file utility
