tweaking color on the print driver.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    [CQ] tweaking color on the print driver.
    For the new Alphards.
    Got a machine going finally, impressed with the speed, but color not so much especially to have a 750c somewhere in the office to compare.
    Does it make much difference if I go tweaking color setting in the driver?
    Idling colour developers are not healthy developers.
    • 23010
    I went that route with a VoyagerE, and made some small improvements, but it was never going to be a Saturn.
    ICC print profiles helped a little, but noting magical. By shifting the color wheel towards red I was able to mask the original problem. I tried literally every driver color adjustment or combinations thereof. I tried 4 different applications, three different driver versions, different firmware versions. Mostly I just made it worse. And spent 15+ hours doing so.
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      this brings up another question, is the Kyo-shiba the same WITHOUT the Fiery?
      edit: not to bring negative attention to this series, this is solely to seek improvement on performance. when I meant fast printing, its FAST! even with pdf format. Scanning operation is zippy as well.
        • 23010
        No. The fiery makes a big difference.
        • dogg_man
          • Jun 2011
          • 48
          Re: tweaking color on the print driver.
          The fiery really does make a difference in color accuracy, get yourself a PANTONE color bridge and ES-1000 spectrophotometer and you can upload any color your having an issue with. Of course this is assuming that the copier is properly maintained.
