FYI CF223 CODE
  • madas
    • Aug 2008
    • 313
    FYI CF223 CODE
    Hi, All
    We had a FS-1118 with the above code. this code was not listed (even on the Fritz list)
    Turned out to be a fault with the engine pwb (not the eeprom)
    Hope this helps as it may relate to other models also.
    madas
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: FYI CF223 CODE
    Where can I find the "fritz list'?
    thz for the heads up.
    Idling colour developers are not healthy developers.
      • 23009
      Re: FYI CF223 CODE
      Thanks madas. Consider it included. =^..^=
      • madas
        • Aug 2008
        • 313
        Re: FYI CF223 CODE
        All good BC. can you point jmaister to the original list posted by Fritz as i can not seem to find it?
        Hi jmaister
        here is a link to an earlier post for the codes but i can not find the Fritz list on here. This has more and also other info.
        http://www.copytechnet.com/forums/ky...tml#post226941
        madas
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          Re: FYI CF223 CODE
          much appreciated!
