250ci Ops Panel Problem
  • daveyball
    • May 2009
    • 314
    I Have a 250ci, that when going into power, the only way to get the ops panel to come back, is to switch the machine off and then on again, it's not the power save button, as you can manually power it off. Any Ideas?
  • Metalvoc
    • Sep 2008
    • 155
    Re: 250ci Ops Panel Problem
    Of course, re-load your firmware if you haven't already. Is there a backlight, with a blank screen? Do you have any lights on the display, or is everything dark?
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
    • daveyball
      • May 2009
      • 314
      Everything is OK, the machine works fine, and it boots up OK, its just it won't wake up out of power save, it will stay on all day, as its used, but in the morning you have to switch on and off to get it to work
      • Jules Winfield
        • Jul 2009
        • 821
        Kinda sounds like Windows 7 when it was still in beta. Updates fixed the Windows 7 problem, maybe firmware updates will fix your's.
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
        • Metalvoc
          • Sep 2008
          • 155
          so after it goes into power save mode, you can't turn it back on with the PS button, and it won't turn off/on with the power button on the display? And you can use the Power Save when its on?
          • daveyball
            • May 2009
            • 314
            thats right, the power save button works as normal, I have reflashed the firmware, but I will try again
            • daveyball
              • May 2009
              • 314
              Came in this morning and it worked, hasn't done for weeks, maybe the ops panel fairies have been in over night
                • 23009
                I'll get flack for this, but I'd try lower firmware, say 9.01
                Just because there are newer versions of the firmware doesn't make then bug-free.
                If it's functioning, I'd wait for the next event. =^..^=
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  *cough, clears throat...
                  WHAT!?
                  Idling colour developers are not healthy developers.
