Waste toner and Alphard.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Goodday, this is not really a verified issue, didnt go through all the step as this is the first time for this machine in this series.
    Machine: #550ci, prints: ~10,000 total, coverage ratio: +8%
    Trouble: false "Waste toner full" detection.
    Found: Waste toner not full but clogged at the neck, and the black rubber part (belly button?) is inward when the container was removed.
    - waste toner auger at the container seems a bit stiff to turn by hand, with the torq limiter in front of it, and small diameter of the coupler, could be an issue later on?
    - since there are two sensors now, WTS1 for full, and WTS2 for almost full(time to order) wouldnt both sensor be logic '1' for the full indication to trigger? (pls see attached)
    - clogging is a concern at the neck.
    just my 2cents.
    *WTS1 is located at the neck, WTS2 is located above the black rubber part.
    **thx to Blackcat for pointers.
    Idling colour developers are not healthy developers.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: Waste toner and Alphard.
      • 23009
      The plugging at the neck would concern me. Is there any way to observe if the auger is functioning? =^..^=
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        Didnt observe the auger. Dont know how to bypass the interlocks. When container is placed in the tray, couldnt turn the coupler by hand I do recall however.
        The auger diameter maybe too wide? There's packing around the wall of the container.
          • 23009
          YC16-9 and YC16-10 on the front PWB provide the 24vdc for the waste toner motor (WTM). I don't see a simulation to run that motor. The auger inside the bottle should be very easy to turn manually, when it's not linked to the motor. If it isn't, I'd take a closer look at the bottle itself. Maybe some sort of manufacturing defect?
          Is the environmental temperature or humidity exceptionally high? Under normal environmental conditions color toner should flow like water, because it is so fine. The auger is almost redundant. =^..^=
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            Carrier is part of the waste now hence added stiffness. The guy tried to loosen up the "stuff" in the container, when he pulled the screw driver up, carriers+toner were standing on the tip.
            edit: not sure on what i just stated, I havent dug my screw driver in the toner pile before.
              • 23009
              Ah, yes. I forgot about the steady supply of carrier being cycled through. It should still flow easily enough, though. =^..^=
              • jmaister
                certified scrub
                • Aug 2010
                • 755
                Didnt have Alphards around so I went and check Saturn's waste toner setup. I tried handcranking with box in and out of the tray.
                It IS suppose to be fluid, there's probably something wrong with the gearing or the container itself from the one yesterday.
