Kyocera FS-C2126MFP error msg
  • Ingersoll
    • Nov 2008
    • 74
    [Error Code] Kyocera FS-C2126MFP error msg
    Has anyone seen an error message like this: This printed out after it printed 1 copy of the print job:
    Symptom: Only one copy was printed while more than one copy was required.
    Cause: RAM disk was full or not activated.
    Remedy: Activate or increase RAM disk.
    It does not have the addtional RAM upgrade of 1 Gb which is required to turn RAM disk ON.
    BUT it should be able to print more than 1 copy of a 1 pg print job!
    • 23010
    Re: Kyocera FS-C2126MFP error msg
    I think that I'd try some FRPO changes. Specifically send this PreScribe command:
    !R! FRPO S7,1; FRPO S6,200;EXIT;
    which breaks down as:
    S7,1: RAM Disk Enabled
    S6,200: Amount of Memory allocated for RAM Disk 200MB
    You can designate anywhere from 0 to 1024MB of the available memory for RAM Disk.
    • Ingersoll
      • Nov 2008
      • 74
      Tech Bulletin TB1 states that no RAM disk w/o adding 1 Gb memory. I asked tech supt about it too. I guess I will update firmware to latest.
      • Ingersoll
        • Nov 2008
        • 74
        Updating Firmware seems to have fixed the problem.
          • 23010
          Thanks for sharing. =^..^=
