TASKalfa 400ci Finisher JAM 00
  • MFPTech
    • 486
    TASKalfa 400ci Finisher JAM 00 at start up, no paper in finisher, checked / swapped sensors, replaced Finisher Board - no change. It's one of those small Finishers.
    Anyone had this problem before please?
    Thanks in advance!
  • marc
    • Feb 2010
    • 56
    Re: TASKalfa 400ci Finisher JAM 00
    Do you get the error without the finisher?
    • marc
      • Feb 2010
      • 56
      There is a QA for this problem see if this can help good look!!!
        • 23008
        Thanks for sharing marc. =^..^=
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          That is only for the B/W machines, we cut a piece of reg roller cleaning brush and stick on the door post that pushes on the bypass transport unit. I suspect one of the door switches isn"t making good contact
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • marc
            • Feb 2010
            • 56
            You right, Venom excuse my mistake
            • MFPTech
              • 486
              The machine works fine without the finisher.
              • marc
                • Feb 2010
                • 56
                Can you check simulation 31 and 241 to see witch sensor is faulty try main firmware update Pack and the option Pack.
