Kyocera Taskalpha 3050ci
  • MPM2140
    • Mar 2010
    • 13
    [CQ] Kyocera Taskalpha 3050ci
    brand new copier, has only 180 copies on it...
    in a run... the is a black band looking section that happens... intermittant...
    this only happens on the black and the colours are fine.
    enclosed is a copy of what it is doing.
    any suggestions ?
    • 22999
    Re: Kyocera Taskalpha 3050ci
    Kyocera color machines do not have a web or any other cleaning method for the fuser. So after you've been running a bunch of edge-to-edge high fill photo images, the fuser can collect some residual toner that clears on the next few pages. Also a paper jam will leave toner on the heat belt. And if you've been running heavy paper on plain paper media settings you'll leave toner in the fuser.
    For starters, make sure that the proper media settings are being used. Also make sure that the fixing temperature settings are at their defaults, and haven't been tweaked up or down. Do you want a long term cure? Design a cleaning web for the fuser. And while you're at it, there a few other machines that can use a web, too. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      this kinda puzzled me for a while.
      have you tried checking if the developer sleeve already have carrier build up?
      Idling colour developers are not healthy developers.
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
        Paul@justmanuals.com
        • kyocera.team
          • Aug 2010
          • 126
          agreed 100%
