It seems like at some point every KYM device with a tandem tray or LCT (Large Capacity Tray) errors out. I have to go in an execute U906 to reactivate the tray. The problem is ongoing and after much searching on here there is still no resolution.
In the past I have gotten away with replacing the paper pick-up assy, but there has to be a more cost effective means to fix this issue. If anyone has dealt with this issue could you please share what you have found to be the best resolution (aside from u906)
Thanks,
Mike
Thanks,
Mike
