KM5030 Print board DIMM KP-893-A and KP-893-B what is the difference?
  • habik
    • 2013
    I have 2 print boards for KM5030, one is showing c0420 when DIMM KP-893-A was installed. I am a bit scared to put the other KP-893-B which is functional to the C0420 board..
    any suggestions, i can't afford to loose this board but also desperate for fix of the one with error C0420
    Firmwares HERE
    • 23008
    Re: KM5030 Print board DIMM KP-893-A and KP-893-B what is the difference?
    I don't have a manual for that one, but C0420 on other machines is a communication error with the Paper Feeder (cassette base). It should be unrelated to the print card. =^..^=
    • habik
      • 2013
      Sorry the code is C0240
      Firmwares HERE
        • 23008
        Well the C0240 code is printer communication, but I can't advise you about whether the other printer board will be compatible. =^..^=
