envelopes
  • luis8832
    • Dec 2008
    • 250
    [Misc] envelopes
    I have a new fs-1128 mfp and it works just fine. The only issue i have is that when they print envelopes they come out wrinkled. Its not a roller issue because its new. Any suggestions would be appreciated.
  • ru4real
    • Aug 2011
    • 13
    Re: envelopes
    Luis8832
    Make sure your envelopes are as flat as possible, no air inside, and as fresh as possible, not damp. I can honestly say I have never had much luck running envelopes on most the Kyocera machines. Wrinkling is unfortunatly a pretty common problem.
    Good luck
    • luis8832
      • Dec 2008
      • 250
      Re: envelopes
      We just got another unit in the office, i tried envelopes on that one also. Same thing, the only way i got the envelopes to come out decent was by changing the media type for the mp tray. The 3 that came out the best was when i changed the media type to letterhead, labels, and custom 1. SCAN0048_000.pdf
        • 22997
        Re: envelopes
        Did you look for the fuser pressure setting for envelopes?
        • ru4real
          • Aug 2011
          • 13
          Re: envelopes
          Yea luis8832, I've had similar results but unfortunitly 3 weeks down the road those settings will give you a completely different result. They are just very temperamental when envelopes are concerned. I just wish Kyocera would remove them from the spec sheet.
          Good luck,
          • luis8832
            • Dec 2008
            • 250
            Re: envelopes
            I have an 1128 in my office, i checked the fuser and see no tabs or levers to change fuser pressure.
            • ru4real
              • Aug 2011
              • 13
              Re: envelopes
              1028/1128 have no pressure tabs for the fuser. Tabs are the 3040/3140 boxes.
              Good luck,
                • 22997
                Re: envelopes
                There is no mention of the tabs in the operators manual either, just lots of qualifications about why it would wrinkle. I expect, most of the time. =^..^=
                • 10871087
                  • Jan 2005
                  • 1143
                  Re: envelopes
                  Envelopes and Kyocera products have never got along with each other very well. You can try a different envelope stock but other than that...
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1868
                    Re: envelopes
                    There are envelope pressure levers under the metal guide above the cassette. Get to it through the back. It's REAL convenient. Like a customer would ever do it.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • ru4real
                      • Aug 2011
                      • 13
                      Re: envelopes
                      Just unboxed a new machine and looked under the metal plate above the cassette, TABS Never knew those were there. Something to try next time.
                      • mita
                        • Sep 2010
                        • 87
                        Re: envelopes
                        also you may want to try the office depot #10 envelope
